Backlight For (auto) Shifter
Old Aug 11, 2002 | 01:23 AM
Ratstix's Avatar
The backlight on my auto. shifter (that lights up the gear letters) only works about 1/3 the time. where should i look to correct this? i took a quick look at teh front of the counsole and didn't see any loose wires.
Old Aug 11, 2002 | 05:40 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
I'd start simple and replace the bulb. Sometimes a bulb's filament can break away stopping it from working, but if it re-contacts itself, the intense heat can weld it back together temporarily.
If you can't see a problem with the wiring, there's always the option of replacing the wires. Run one to a good earth, and the other to your light switch, or even your sidelights themselves.
Good luck
Si
Night rider327
Feb 25, 2016 09:50 AM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 2, 2015 09:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
armybyrd
Sep 26, 2015 03:37 PM
