Where can I learn more...
Old Aug 12, 2002 | 03:16 AM
traumatech's Avatar
Does anybody have any good tech articles on using ignition systems with computer controlled vehicles. I'm still in the planning stage (as I have been for a couple of years unfortunately) but this is one of the last areas I need to work out. I'll be running a LTR TPI on a 383 with either a Gen VII or FAST SAFM. I know I could probably use a stock computer if I burned my own chips, but I like technology and I like the ease of tunig that a compputer interface will give me. Now I just need to learn how to light all of this up. I think I'd like to go with Accel products simply for cost reasons (gotta trim cost somewhere) but any suggestions would be appreciated. Thanks.
Old Aug 12, 2002 | 09:52 AM
92RSB4C's Avatar
If you're talkin about burnin chips, then you're on the wrong board. Try the DFI & ECM board, and the DIY PROM board.
Old Aug 16, 2002 | 03:14 PM
traumatech's Avatar
I'm using DFI system to eliminate chip burning -- I've got that figured out already. I'm talkin gabout how to use an MSD sstem, or Accel 300+ with that DFI. How do I get the appropriate amount of spark, is there too much, how will everything interact, how will advance be controlled, what kind of triggers will I need if I go with a more detailed ignition. I've got ignition questions, fuel management questions. Thanks.
Elephantismo
Feb 13, 2019 12:51 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
drumstixer
Sep 29, 2015 03:02 PM
mfp189
Sep 27, 2015 09:25 AM
