temp sensor's busted
Old Jun 28, 2001 | 10:54 AM
85 - LG4's Avatar
Replaced my temp sensor cause I broke off the plug on the old one. New one says engine is running at nearly 220 degrees. The old one used to run with the needle just under the line between 100 and 220. This can't be right because I drove down the road w/ the heater on full blast for 15 min. and it didn't make a difference. I have a 195 thermostat.
700-R4 all original except Accel ignition, Kenwood KDC-X815 CD player. original for now anyway...
Old Jun 28, 2001 | 08:42 PM
85 - LG4's Avatar
anybody?
Old Jul 1, 2001 | 03:56 PM
orange rocket's Avatar
New sensor bad? Mine runs where your used to. Did anything foul up the end as you were puting it in or bad connection/ resistor?
Old Jul 1, 2001 | 03:57 PM
Old Jul 1, 2001 | 08:45 PM
jase's Avatar
Change thermst. that might be a new problem.
Old Jul 2, 2001 | 06:20 PM
85rollin's Avatar
Hi, this is 85 - LG4 under my new alias, the old one just wasn't me. Anyway the stat is new and I went to great pains to make sure it was in right. I'll try to check the sensor resistance and whether the thing was fouled when I put it in.Does anyone know what the temp sensor resistance should be at? Also, the coolant was fairly hot when I put the new sensor in, could this affect it?
[This message has been edited by 85rollin (edited July 02, 2001).]
Old Jul 2, 2001 | 09:18 PM
jase's Avatar
The colant may need to be changed and the radiator flushed to help your problem.The other I can't help you,but I would take it back and say it was faulty just to see if you still have the problem after a good radiator flush.
Old Jul 5, 2001 | 06:29 PM
MartyMcFly's Avatar
Car: Z28
Engine: Edelbrockified 305
Transmission: 700-R4
Just trying out my signature
LUDICROUS SPEED [b]GO!!!b]
Old Jul 5, 2001 | 06:32 PM
MartyMcFly's Avatar
Car: Z28
LUDICROUS SPEED [b]GO!!![b]
Old Jul 5, 2001 | 06:33 PM
MartyMcFly's Avatar
Car: Z28
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
