dome light stays on.. is this causeing my battery to drain over night?
Old Aug 15, 2002 | 10:06 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
well for some reason my dome light wants to stay on all the time.. even when the cars is not on. i took out the bulb so its not draining any energy from the battery, but in the morning.. or 4 hours later, the battery is dead. could this be my problem.. if so how do i fix this.? i hope this is enough info on my problem.. if not ill post more in the morning. :lala:
Old Aug 16, 2002 | 12:19 AM
Morley's Avatar
Are the lights by the driver and passenger's feet on too? You need to figure out why the dome light is on, there is a circut that may be shorted to ground and causing the drain weather or not the bulb is in.
Old Aug 16, 2002 | 09:01 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
no, the floor lights are not on either.
Old Aug 16, 2002 | 11:50 AM
MdFormula350's Avatar
sounds like a short somewhere...
have u did anything to the car recently?
Old Aug 16, 2002 | 11:53 AM
if the dome light stays on even if you have the door closed then something is wrong.. have you checked the switch for the interior light dimming you might have it all the way up, so that the lights stay on no matter what i have did that a few times before in my other cars.
Old Aug 16, 2002 | 01:58 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
no. i checked that..
Old Aug 16, 2002 | 04:51 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
do your floor lights come on when open the door or turn the switch?
I would check the button switches at each door...they pretty easy to remove...just check to make sure they arent stuck and corroded.
Old Aug 16, 2002 | 06:01 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
nope.. they done come on.
Old Aug 16, 2002 | 08:36 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Well if they arent coming on at all I would replace the bulbs to see if they do...other than that I would again look at the headlight switch and the door switches. hmm as a way of determining if your interior lights are drawing power with while the car is parked, I would pull the fuse, if it isnt dead in the morning its your lights...if it is still dead, look elsewhere
Frozer!!!
Jan 19, 2024 04:55 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 21, 2015 01:54 AM
