spaztic speedo!!!!
Old Aug 24, 2002 | 02:35 PM
Doogie92Z28's Avatar
spaztic speedo!!!!
when i am driving my speedo will shake ratle and roll from different mph to another and sometimes jus stop on like 50 when i know i am going faster. is there something wrong with the cable that controls it? need help. thanx
doug
Old Aug 24, 2002 | 08:51 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
There is no cable, it's electronic, check for a short or just replace the speed sensor on the tranny, it's on the drivers side of the tranny back by the drive shaft. it's 50 bucks at O'Rally Borg Warner part so it has a life time warrenty.
Old Aug 24, 2002 | 11:19 PM
thanks man. did u have the same problem and thats why you knew what was wrong its all cool though.
doug
Old Aug 24, 2002 | 11:26 PM
Well I broke my speed sensor trying to hammer thru one of the transmission to trailing arm bolts so I had to buy a new one, thats how I know it's there and how it works on our 92s 91s
Old Aug 24, 2002 | 11:29 PM
But it could also be the dash itself that the magnitic needle has died, lets hope not or you will be looking at the bone yards a long time for a new dash cluster.
Old Aug 25, 2002 | 12:07 AM
i am just not going to mak that an otio. i am gin to say it is the sensor on the trany an that is that. the cheapest fix. that is the way i want to go. haha
doug
Old Aug 25, 2002 | 01:05 PM
Yep I think so too, all the thing on the tranny is, is a magnatic pick up so that would explain the jumpy needle if it's not picking it up.
Old Sep 8, 2002 | 02:55 PM
DracoZK's Avatar
Car: Z28
Engine: 350 L98
hey
is it common for the pick up on the tranny to go bad?
just wondering
thanks
Kyle
Old Sep 8, 2002 | 03:14 PM
Not that I've heard, mine was good still I broke it when I hit it with a hammer when trying to put the trailing arm blots back in.
So I think it's a rare thing.
Old Sep 8, 2002 | 03:48 PM
DracoZK's Avatar
Car: Z28
Engine: 350 L98
i was just wondering, cuz when i was out driving this morning i noticed my speedo kinda jumping from 40KMH to 50KMH
so i came on here to see what i could find
i figure i might have pushed my needle on a little too tight when i had it out looking at it for some idea for a dash swap that im working on
thanks
Kyle
Old Sep 8, 2002 | 04:57 PM
NOW wait a second if you don't have an electic speedo you don't have a mag pick up. 89 and below had cable driven speedos I believe and 90 and up had all electronic dashes and they had mag pick ups. So check your year.
Old Sep 8, 2002 | 09:51 PM
DracoZK's Avatar
Car: Z28
Engine: 350 L98
i have a 92 and i know that its electric
its it possible to through the needle off if it is electric?
doesnt it work of the "signal" it gets so it wouldnt matter if the needle is moved or what have you ... ?
i found out driving home tonite that at the higher speeds the needle moved nicely but it was just in the lower speeds that it kind of jumps
best regards
Kyle
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
