My LT1 is dead
Old Sep 5, 2002 | 09:58 AM
mat89RS's Avatar
My LT1 is dead
Guys,
I came back home last night, got in the driveway, backed out of it to park in the street. Put the car in drive and it stalled.
Now I tought it ran out of gas but no, the car has no spark...wtf ?
So I changed the coil, still no spark. I checked for loose wires , didn't find anything.
Now I'm thinking it's the optispark, but why would it just die like that ??? is it possible ???
Can I put a 95 vented optispark on a 93 LT1 ??? will it work ???
I can get a great deal on ebay right now but I need to know fast, the auction is ending like in 1 hour.
Old Sep 5, 2002 | 11:31 PM
mat89RS's Avatar
I also noticed that spark plugs are dry after cranking for a long time. Maybe no injector pulse.
I check the coil. it's good.
I tought it could be vats , so I checked it and it's fine, and since the engine is cranking it means that it's working.
I also checked the power feed to injectors, it's all good.
Now since it and no spark, no fuel. I'm thinking it might not be the optipark.
Anybody has suggestions ?
Old Sep 6, 2002 | 01:32 PM
mat89RS's Avatar
Anybody as a service manual for 92-93 corvette-93 camaro ???
I need pages from "Engine cranks but will not start"
Old Sep 6, 2002 | 04:11 PM
mat89RS's Avatar
I read in an old post :
If the injectors aren't firing then the ECM isn't seeing the reference pulse from the distributor. Without the pulse it will not fire the injectors. You need to findout where the pulse is not getting through.
Is it the same with Lt1's optisparks ???? could it be a faulty optispark ???
Old Sep 7, 2002 | 12:35 PM
Morley's Avatar
If there is no spark and no reference pulse to the ECM, I'd lean towards the distributor, but I don't know much about the Optispark system. I have read on the GMECM mail group that most there think they are junk and prone to failure.
Old Sep 7, 2002 | 01:21 PM
mat89RS's Avatar
Ok got an update, wired my ses light properly and also my aldl connector.
Now it's trowing code 46 ....
Which is VATS ALERT, the Haynes manual says " Check for faulty circuit from ignition switch to theft deterrent modem or ECM/PCM"
I have check all the connections, there's
bat power, ignition power, starter enable relay feed, resistence is ok, fuel enable signal, I don't know how to test it, and I checked also ground, it's good ...
I also checked all the ignitions power feeds, and all bat feeds to ECM, nothings wrong
does that look like a faulty VATS ???
Old Sep 9, 2002 | 07:42 AM
vortechLT1's Avatar
Re: My LT1 is dead
Originally posted by mat89RS
Guys,
did you get the opti from E-bay?
Old Sep 9, 2002 | 04:45 PM
mat89RS's Avatar
I did not . I'm getting a new passkey II.
Old Sep 10, 2002 | 06:20 PM
mat89RS's Avatar
Anybody knowns how to program a new passkey ?
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
