question regarding wiring behind stereo
Old Sep 5, 2001 | 07:30 PM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
My 92 camaro has a problem with the AC fan. I took the radio out and jiggled some wires around back there and the fan will come on but then if I release pressure from the wires it cuts itself off
Anyone know how easy it is to remove the controls so I can see if it is corrosion or what not on the back side of the connections?
1992 B4C
as you know
1 of 589 made!
Only mod - - K&N
Old Sep 6, 2001 | 01:34 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you have the trim plate off & the radio is already out, then 4 more hex screws will get the HVAC controls out right above. There is just barely enough slack in there to be able to pull the controls out & unplug things to check. It's really not that fragile.
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited September 06, 2001).]
Old Sep 7, 2001 | 01:11 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
There are 3 7mm bolts that hold it in. The only electrical portion of the HVAC is the fan and the wires for the lights, everyting else is vacuum driven. The switch for the fan comes out easily once the climbate control center is out. Check for wires grounding on each other.
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
    !cat
    CAI W/ K&N
    15.559 @ 88 MPH
    (Not good enough)
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
