volts go from 13 to 10 or less when A\C is turned on.
Old Sep 16, 2001 | 01:04 AM
breathment's Avatar
why is it when i turn on the A\C it drops the volts down REALLY low when im idling. with A\C off its perfect, and when im cruising its perfect Volts with A\C on. does it really take that much power to keep the A\C clutch engaged? Alt. is about 3 months old.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 16, 2001 | 03:23 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
yes it does plus, the fan kicks on at the same time drawing juice too. There's more techy stuff than that for why it causes more drain at idle but, I'll leave that be for simplicity reasons (among others at this time of night )
btw... the little burnout smilie in your sig is too funny
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited September 16, 2001).]
eightsixseven
Dec 16, 2024 01:50 PM
Fronzizzle
Mar 18, 2019 08:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
