Alternator overcharging sometimes
Old Sep 9, 2002 | 08:55 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Hey guys help me figure this one out. Replaced the alternator in the IROC, (305 TPI) and here's the problem. Sometimes everything will be normal, then all of a sudden my alternator will be putting out almost 17 volts!
I'm thinking the problem is in the wiring. Could it be a bad negative battery cable, bad voltGE input wire to the alternator? Any ideas where to start and check?
TIA
Old Sep 9, 2002 | 09:24 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
you should check grounds and wires first, but it sounds more like the voltage regulator in the alt. is bad. i could be wrong but it sounds like you should take that back out and have it tested if you dont have a bad ground
Old Sep 10, 2002 | 06:14 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Did you have this problem prior to replacing the alternator? If not then suspect the replacement.
Old Sep 10, 2002 | 06:37 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
When I first picked up the car I had this problem. Thought it was the alternator so I replaced it. That one was dead, so I replaced it again with the present one.
Old Sep 12, 2002 | 12:21 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Anymore suggestions? I wanna fix it this weekend.
Old Sep 12, 2002 | 10:12 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
i got the wiring diag. for a tpi bird here but it should be the same
coming out if your alt there should be a two wire conection. one brown that goes to the fuse panel. the other black or black w/red stripe that wire should go to the battery either directly or to a junction box first. make sure that one has good clean contacts
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
