Speed Limiter
Old Sep 2, 2001 | 12:12 PM
vrjg05's Avatar
Speed Limiter
I recently read the post on removing speed limiter and it stated that it could be bypassed by installing an off and on switch. The article said to cut a brown wire labed A 10 but I checked and mine does not have that wire. But the car does not pass the 110 mark. Please Help.
Old Sep 2, 2001 | 04:56 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You shouldn't be going that fast anyways
A 10 is the PIN placement on the ECM connector. The smaller of the 2 connectors is where the brown wire should lead into. The wire is brown though
The mind is like a parachute, it only works when its open
Old Sep 4, 2001 | 07:24 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
What year is the car & what engine?
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Sep 11, 2001 | 06:29 PM
vrjg05's Avatar
It is a 1991 Z28 With all stock 305 5.0 engine and a 700R4 tranny. The speedometer reads 110mph.
Old Sep 21, 2001 | 12:35 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
can you just buy an aftermarket chip to eliminate the speed limiter? i personally would do that before cutting wires.
'92 Z28,t-top,PPG jet black,5.0L TPI,Auto w/stage 2 sft. kit,
michelin pilot 245/50/ZR16 tires,polished plenum/intake,flow tech 3" exhaust,PIAA driving lights,2 kicker 10" comp vr subs,jl audio componet set in q form kick panels,kicker ix405d 5 chanel amp,pioneer deh-p735 deck
Old Sep 21, 2001 | 05:00 PM
KlayBuRn's Avatar
me and my friend burnt a chip to get rid of that, all it does is just cut fuel at that speed, make sure your tires can rotate that much
Old Sep 24, 2001 | 10:51 AM
vrjg05's Avatar
How do I determine if my wheels can turn that much. And when you burnt the chip all you changed was the fuel cut-off, or other stuff like fuel ration or anything?
Old Sep 24, 2001 | 02:23 PM
Check the speed rating on your tires - check out www.tirerack.com for info on speed rating. The PROM parameter to modify is "fuel cutoff speed".
Tim
Old Sep 25, 2001 | 07:37 AM
hotpowerandperf's Avatar
On the 91 TPI the VSS wire to cut is the yellow wire at B9. As a word of warning this will disable your speedometer and may have other adverse affects. I agree with the other who say you should have the prom changed to what your tires can handle. If you do not have access to a burner there are many here that can help you out
John
Heart of Texas Power and Performance
Old Sep 25, 2001 | 09:09 AM
IROC&ROLL
Guest
Posts: n/a
The speed ratings of tires are for sustained speeds (around 30 minutes if memory serves). A brief jaunt above the tires ratings will not cause them to disintegrate.
Old Sep 26, 2001 | 10:41 AM
vrjg05's Avatar
Ok when you say that it is going to disable my speedometer will it just jump on 110mph or will it go back down to 0 mph while it is while the VSS is shut off.
Old Sep 26, 2001 | 11:37 AM
In 91 the speedometer was electronic. It was driven by the computer through the 400 pulse per mile output. The only way the computer can generate this signal is to use the input from the VSS. If you remove the VSS signal the speedometer will drop to 0.
John
Old Sep 26, 2001 | 04:29 PM
The speedo output from the ECM is actually 4000 pulses per mile, not 400.
Tim
Old Sep 27, 2001 | 07:30 AM
You are right 4000 not 400. Sorry about the typo.
John
Old Sep 28, 2001 | 12:43 PM
pred1tor83's Avatar
You mean if i was to try to go past 110 in my 1987 iroc (5.0 w/ 5 speed) i couldnt?
guess i'll try later today after school.
"I'm not an "expert" per say though i did sleep at a holoday in last night."
Still lookin for the right Z
Old Sep 28, 2001 | 10:56 PM
Lack of a VSS signal will not prevent you from exceeding 110 mph. It will cause an ELECTRONIC speedometer to read 0 mph. A cable driven speedometer will read actual MPH regardless of whether a VSS signal is present or not. I believe that 87 is cable driven and 91 is electronic.
John
Old Sep 30, 2001 | 11:46 AM
vrjg05's Avatar
So what would have to be done if I want my electric speedo to read after 110? Do I have to get a speedometer that reads 140 or will the burnt chip allow me to.
Old Sep 30, 2001 | 01:07 PM
JohnnyIROC-Z's Avatar
Car: 1991 T-Top RS
Engine: 305 TBI
What they are saying is IF you cut this wire your speedo WILL NOT work. NO matter what speed you're going it will read ). THe needle will not move because that wire is a wire that controls the speedo.
1987 IROC-Z T-Tops wait... GUTTED MAF!
Old Oct 1, 2001 | 11:11 AM
vrjg05's Avatar
So once again can I change my speedo to a 140mph then burn a chip that will allow me to reach that speed? If yes tell me wether it is a direct bolt on or do I have to mess with something more than just the speedo.
When burning the chip, if anyone knows what has to be changed? I know the speedlimiter, but what else? How about that 4000 pulses per mile? By the way what is that? Thanks
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
