NEED HELP NOW!!!!!!!!!!!!!!!!!!!! Gauge wiring, PLEASE HELP!!!!!!!!!!!!!!!!!
Old Oct 13, 2001 | 05:48 PM
Monkie's Avatar
I have an Air/Fuel ratio gauge and I need to know the best way to mount it. I have a 92 Camaro and I cant find a good place to go through the firewall. The instructions say...
Red wire: Connect to a fused and switched 12v positive source that is turned on and off with the ignition switch.
Black wire: Connect to good engine ground
Violet wire: Connect to oxygen sensor signal wire. Connect to vehicle wiring harness, not oxygen sensor since some oxygen sensors use shielded wire.
My main question is where could I bring the wires through the fire wall? And What wires in my car should I splise into? I need any help I can get guys!!!! I need to have this done by tomorrow night!
[This message has been edited by Monkie (edited October 13, 2001).]
Old Oct 14, 2001 | 05:14 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You shouldn't need to run anything through the firewall, you should be able to access all the wires you need under the dash.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
