fuel pump& tps senor
Old Oct 12, 2001 | 02:33 AM
sonnyb's Avatar
1.FUEL PUMP IN MY 1991 TPI 5.7 CID CAMARO Z28 RUN WITH THE KEY ON OR OFF. WHAT DO YOU THINK CAUSED THIS AND HOW WOULD I REPAIR THIS? 2. no power is getting to the tps senor. could there be a short in the wiring or a bad computer?
Old Oct 13, 2001 | 05:48 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Not sure about the TPS, you'll need to trace some wiring.
Re: the fuel pump running all the time, my guess is either the relay is stuck, or the oil pressure switch is stuck.
Old Oct 15, 2001 | 03:59 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The grey wire should have 5v+ on it. If you use a multi-meter, it should have power (key in 'run' position) between that wire & a chassis ground (or any negative ground point)
Test at the ECM (same grey wire) for the same 5v+ be aware,, the EGR solinoid wire is the same color (the TPS is on the larger of the 2 ECM connectors) If you have voltage at the ECM, there is an open in the circuit somewhere.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Oct 15, 2001 | 04:06 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Either the FP relay is shorted or the oil pressure sender / fuel pump switch above the oil filter is shorted.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
92camaroJoe
Jul 29, 2023 07:57 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
