Hatch pull down wiring, please help
Old Sep 19, 2002 | 11:43 AM
dirtybird's Avatar
I have a 91 formula, the sweet plastic piece broke on the hatch pull down. I had some problems w/ the plastic sliders when i was trying to fix that and numerous other problems. IT was like 3 months later that i went back to fixing the hatch. Well it was so long that i forgot where all the wires went. If anyone could provide me w/ some pictures of there pull down and the wiring would be much appreciated. The only thing is the black wire on top of the pull down i believe it is power. I just need to know where it goes, i tried to ground it, but that did not work, please dont tell me i need to buy a new motor, i will cry hehe. I think that is the same wire for the hatch button inside the car. Any help would be great, thanks, and sorry for the long post.
Old Sep 24, 2002 | 03:20 PM
confucius101's Avatar
ouch
man i'n trying t remember how it's all hooked up but i'm drawing blanks tell ya what look up
Lonsal or Topdownsoultions
he should be able to help you out
Old Oct 10, 2002 | 08:52 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
yeah...get in touch with Lon at top down solutions. he is the master of the hatches. He has really good replacment parts as well. The only thing I can tell you off hand about the wires, is there should be a red wire that is the power for the pull down. It should connect with the blue wire coming out of the relay. The black wire on top is for the "pop" motor I believe. But talk to Lon, he can tell you better. good luck...i hate my hatch motor.
Justin
Old Oct 12, 2002 | 11:06 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The black wire with a black connector on it is for the solenoid release. The blue wire connects to the red/white wire for power. Be sure to connect the ground wire from the 10mm bolt (that attaches the solenoid to the latch) to the common gound location below on the body.
Lon Salgren
Top-Down Solutions
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
