high beam fix
Old Sep 21, 2002 | 10:04 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
high beam fix
Okay I know what the prob is with my headlight high beam switch. I need to move the switch on the steering column. Now I can see two screws on the top left of the column and I know they will be a beotch to get, but are there also two on the other side? Also do I have to drop the column to get to them and if I do what all do I have to remove? I've been under the dash to disconnect the clutch pedal ( need the plastic part that holds the clutch to the shaft arm cause I broke it. If you know where to get one please let me know) and I saw the high beam switch and decided to fix it once and for all. any help would be appreciated.
Old Sep 22, 2002 | 11:50 PM
2vmodular's Avatar
high beam switch is much easier to access if you lower the steering column a little bit.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Linson
Sep 21, 2015 01:08 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Stryker412
Sep 7, 2015 09:11 AM
