quick CC questionn..please read
Old Oct 29, 2001 | 08:45 PM
CamaroEFI's Avatar
Does andbody know where the cruise control transducer is on a 91 RS (TBI) Camaro?
Old Oct 30, 2001 | 02:05 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If you are looking for the cruise control servo, it is located between the vapor canister and the radiator tank. The servo uses vacuum to actuate the throttle. The vacuum applied to the diaphragm is controled by two electromagnetic valves inside the servo.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Oct 30, 2001 | 02:54 PM
CamaroEFI's Avatar
thats what i thought but as i looked there was nothing there. i looked through a Hayes repair manual and the CC transducer is supposedly where the speedo cable hooks up to. so whats going on and where is the speedo cable? thanks
Old Oct 31, 2001 | 01:46 PM
The Hanes manual in incorrect. Your '91 does not have a speedo cable - it uses an electronic VSS. The VSS buffer is located near the ECM & it drives the VSS signal to the ECM, the cluster & to the cruise control module - which is a black box mounted near the ECM, as well.
Tim
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Sep 6, 2015 10:42 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
andy74
Sep 3, 2015 08:41 AM
mrdevontay
Sep 2, 2015 08:04 PM
