Battery Drain.
Old Sep 23, 2002 | 08:30 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Battery Drain.
Ok, so I did a search first and found nothing on this so here it goes. I've had a battery drain for a while. At this point I've almost killed my 2nd Optima battery in 2 mo. SO here's what I did. First I disconnected the negative power wire from the battery. Next I put a test light to the negative post on the battery and connected it to the cable. Light immediatly lit up. Pulled all the fuses, light stayed on. Jacked the car up and pulled all the starter wires off. Light goes out.
Ok, so now we know it's in the starter area. So I put the large cable that goes directly to the battery on. Light is off. Put on of the small cables on, light is off. Last I put the connection that has 2 wires going into it on, light turns on.
So here's the Question of the day: What is this connection and why would it be causing the battery to drain?
Also, now my new mini starter will not turn over. I think it might be dead. Is this actually the cause of the problem?
Help please, I'm despirate at this point.
Thanks,
Eric
Old Sep 24, 2002 | 12:17 PM
CraZ-28's Avatar
Car: 1991 Z-28
Anybody?
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
