Help with horn
Old Nov 3, 2001 | 10:37 PM
un4givin89's Avatar
Help with horn
Horn don't work, what should I try and test?
un4givin89
Old Nov 4, 2001 | 12:04 PM
Vader's Avatar
89,
If most other electrical items on the car are working correctly, the fusible links are likely O.K. Start with the fuse panel HORN fuse.
Check the horn relay, located in the "Convenience Center" under the dash. That would be the white cube on the swing-out assembly:
If the system is working, you should be able to hear it "click" when the horn sounder is pressed. If the relay checks out, but doesn't "click", you may have a problem in the steering wheel. There is a horn ring and contact just behind the steering wheel trim, and foil switch bars in the steering wheel cover.
NOTE: If you have an air bag, there are some special precautions to take when disassembling and reassembling the wheel and column parts.
If the relay does "click" the steering wheel os O.K., and either the relay contacts are failing, or you have a supply or ground connection problem at the horns, failed horns, or no power to the relay load contacts (fuse panel again).
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 4, 2001 | 09:32 PM
un4givin89's Avatar
Thanks, I'll try that.
Veaceonee
Sep 29, 2016 08:15 PM
Fox118
Sep 1, 2015 04:07 PM
tc7761
Aug 30, 2015 09:45 AM
Stauf
Aug 24, 2015 08:31 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
