Underhood light question.
Old Nov 4, 2001 | 12:51 AM
slowpoke's Avatar
Car: 1987 Z28
Axle/Gears: 273 Limited Slip
I have a 87 model Z28. The underhood light blows fuses. The little four amp fuse in the line. It seems to do it after the hood is closed a while. Put a new fuse in, light comes on. Kind of lower the hood a little to make light go out, and it will. Then I raise it back up and it turns back on. It blows the fuse after setting with the hood closed for a while. I'm not sure but the light seems to be connect into a spliced wire going to the A/C components on the firewall, the other wire seems to go towards the other side of the car behind the engine. They are both red in color. I would appreciate any help I can get. Thank you.
Old Nov 4, 2001 | 05:44 AM
Omar's Avatar
Is there any wire exposed right at the base of the bulb holder? I was having the same problem, and I had to use some heat shrink and some wire loom to solve the problem.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Nov 4, 2001 | 07:45 PM
slowpoke's Avatar
Car: 1987 Z28
That was it. I don't think I would have thought of that. Thank you Omar.
Old Nov 5, 2001 | 01:29 AM
Omar's Avatar
I'm glad I could help.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheExaminer
Sep 6, 2015 11:40 PM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
andy74
Sep 3, 2015 08:41 AM
