How do I check to see for a electrical leak or battery drain??
Old Sep 24, 2002 | 12:22 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
I did do a search and it told me to use an ammeter to check for amps but what do you hook it up to?? Do you hook up one side to negitive and one to the positive? I really dont get what it means?? please explain?
Old Sep 24, 2002 | 01:31 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Put the ammeter in series with the positive cable at the battery. Which means put the black lead from the ammeter to the positive post on the battery, and hook the red lead to the positive cable for the car. If there is a draw on the system, then the ammeter will show a draw. To find what is making the draw, have someone look at the meter while you are pulling fuses. Pull one fuse, see if it goes away, if not, put the fuse back in and keep going till you find which circuit is making the draw.
Hope this helps.
Old Sep 24, 2002 | 02:44 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
So I unhook the positive terminal on the battery. Then I Put the Red prong on the battery terminal and I put the black one on the Cable that I just unplugged right? can I use a voltmeter for this>? Its all i have. what should I set the volt meter to?
Old Sep 25, 2002 | 11:30 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
That is correct. Most volt meters will have a setting for Amps Drawn, it should be something like Am, or mA which is for Milliamps. A digital meter is the best way to go, but the old analog needle style will work, you just have to watch for the slightest movement.
Let us know how it goes.
BRoss99
Aug 10, 2025 05:08 PM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
djmarch
Aug 9, 2015 05:27 PM
