just replaced VSS..no results
Old Nov 9, 2001 | 05:21 PM
CamaroEFI's Avatar
i just got done replacing the vehicle speed sensor because the speedo and cruise control doesn't work at all. well, i went for the test drive and no good news...i just wasted $40. Does anybody have any ideas on what the problem could be? thanks
Old Nov 9, 2001 | 05:25 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
If your speedo isnt working, I would check to see if you speedo cable is hooked up or broke. This might be the problem. Hope this helps
1989 iroc-z 350 TPI, auto trans, leather int. t-tops, edelbrock headers and cat back system, SLP cam, crane double roller chain, 4 wheel disc, and aftermarket hood. Iroc-z's forever, Ford Mustangs NEVER
Out-Cast
Dec 31, 2015 04:40 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
