headlights and tilt steering
Old Sep 25, 2002 | 08:01 PM
91RS_underdog's Avatar
the only way i can get my headlights to go from low beam to high and vice versa is when my steering wheel is all the way up. when i try from a lower postion the lights flash on and off. Thanks in advance
Jonny
Old Sep 26, 2002 | 04:04 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
It's probably in the headlight dimmer switch. I've had a car's turn signals come on when i tilted the steering wheel to a certain position. It was the switch. I don't really know how to replace it though....
Old Sep 26, 2002 | 05:04 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Take the plastic crap off from under the dash, remove the 4 bolts to the column to lower it (red arrows) and the the switch is on the lower part of the column (green arrow) held by 2 more small bolts, you can also adjust the position of the switch a little. Not difficult, but not the easiest of access.
Old Sep 26, 2002 | 05:47 PM
thanks for your help i'll give it a try
Veaceonee
Sep 29, 2016 08:15 PM
PurelyPMD
May 5, 2016 04:57 PM
codeysabatini
Sep 20, 2015 11:36 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
