HEI Coil upgrade
Old Nov 9, 2001 | 08:43 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
HEI Coil upgrade
Greetings gurus!
My 86 Camaro 305 LG4 is modded as per my sig. The problem I have is typical: the engine wants to lay down and puke at 4000 to 4500 rpm. It gets mighty unhappy at having to work so hard and from what I can gather on this forum it is the fault of the stock GM HEI coil.
Is there a really good replacement coil for my distributor? (It is totally stock other than a Crane vacuum/curve kit.)
Also, I want to avoid having to replace the stock cap and rotor. Who makes an excellent coil that runs jim dandy with my setup?
1986 Camaro Sports Coupe
Flame Red Metallic with Black accents and Red interior
T-tops, variable wiper, power hatch, rear defrost, third brake light
LG4 305 V8, Hooker Shorty headers, 3" pipe into Walker Quiet Flow dual exhaust
Edelbrock Performer intake, "Damonized" Q-Jet 4bbl, K&N filter, Crane ignition kit
TH700R4 transmission and Derale cooler
Air conditioning, power windows, power door locks, power brakes, power steering, tilt wheel
Kenwood cassette, Pioneer 6x4 component front speakers
Rockford Fosgate 6x9 Punch rear speakers
Z-28 front and rear sway bars
Aluminum slots and Goodyear 225x60R15 Eagle HP tires
243 horsepower and 326 foot pounds of torque at the flywheel
_ _ _ _ _ __ _ _ _ _ _
Yea verily, and he smote the smog heathens from his small block Chevy, even from the air pump to the converter ...
Todd 1:1
Old Nov 10, 2001 | 12:17 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I put an Accel "super coil" on my camaro,, it now craps out at 5k instead of 4500. Didn't really help much of anything else thought,, but my camaro is a heap as well.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Nov 10, 2001 | 12:35 AM
Engine: 305-4v
<font face="Verdana, Arial" size="2">Originally posted by deadbird:
</font>
lol
Old Nov 10, 2001 | 09:25 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I'm usually pretty sceptical when it comes to aftermarket products claiming great gains
when replacing good factory part, but....
I recently replaced my coil in my stock HEI
with a MSD HEI coil. The car wa "OK" before
i changed it but thought it could be improved
(throttle response). I got the steal center pin (recommended) too. Well there was a nice noticable difference in throttle response
with it. Definitly worth the money. Apparently their MSD HEI module combined with their MSD HEI coil are about all the ignition you'll ever need. I haven't got the module yet but it's on my list. I don't know if it made my car faster, I'd have to do back to back testing but it seemed to work as promised. If you've got some real problem like bad plug wires or leaky valve guides
or something, this won't fix it. But if ya want to upgrade to a better coil, this is a good one.
Old Nov 11, 2001 | 04:54 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If you're still running the stock cam, that could also be the reason why it's starting to lay down after 4000; mine *used*to do that until I swapped in one that has .420" lift both intake and exhaust. It came out of another engine, so I don't have any other specs on it, but it now revs freely to 5500 which is as high as I dare take it because of the mileage on the engine (over 217,000 miles).
If you do replace the cap and rotor, get a cap with brass terminals - they don't corrode over nearly as quick as the more common aluminum terminals.
I'm running an Accel HEI Supercoil, it's not bad by any means, but there are better ones available.
Pete
Pete's Place
HiOutput Tech Page
83 SC..former V6...now 216+k mile LG4/5-speed.. 14.891@95.54
Old Nov 11, 2001 | 05:52 PM
Engine: 305-4v
Well, that Proform 50,000 volt coil has certainly made a difference!!!
I was pretty skeptical whether or not it would--I mean, either the plugs are firing or they're not, eh?
Not so fast! I can tell right away that it is idling even smoother than it was before, and I thought it was tuned really well, what with my Bosch Platinum plugs (which really do make a difference, in my opinion). But this coil has made it idle as smooth as a baby's bottom. There just isn't even a ripple now!
And, interestingly enough, the exhaust has quieted down. This is surprising but I suppose that even minor misfirings will make it louder.
The carb seems to have settled down now, too. Hmm, who'd have thought that? Of course it was warmed up really well by the time the coil went in, but still
I'll keep a critical ear open for any carb bogging over the next few days when it is cold. Of course QJets don't like to behave themselves for at least 10 minutes, but this one has been cranky about opening the secondaries smoothly so we'll see.
The party is still over at 4500 rpm (though I did get it would up to 4700 on the way home) so it is probably a tired out set of valve springs, or maybe the cam like was said.
Old Nov 11, 2001 | 11:11 PM
Engine: 305-4v
test
[This message has been edited by Sitting Bull (edited November 11, 2001).]
Old Nov 11, 2001 | 11:14 PM
Engine: 305-4v
<font face="Verdana, Arial" size="2">Originally posted by Sitting Bull:
test
</font>
Crane vacuum advance kit and Proform 50,000 volt HEI coil
Todd 1:1
seiplentz
Aug 19, 2019 06:02 PM
Fronzizzle
Feb 9, 2017 09:31 AM
timonator
Sep 17, 2015 06:57 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Jlanz55
Sep 6, 2015 03:05 PM
