Signaling
Old Oct 1, 2002 | 05:41 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Signaling
MY right signal light doesn't work. ( it does but...)
when I turn my signal light to go left, It flashed on the dash, and the light itself like it's supostu.
When I click it to turn right; The light on the dash stays -> (solid) and doesnt flash. The right signal light does come on, but it doesn't flash.
What gives?
Old Oct 1, 2002 | 09:52 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Have you turned in on and looked front and back for a burned out bulb ? Usually the most common culprit for a signal that doesn't flash if the other side does. A bad ground could do the same as well though.
Old Oct 2, 2002 | 12:49 AM
2vmodular's Avatar
Dual filament bulbs have confused a countless number of backyard mechanics.
Old Oct 2, 2002 | 10:56 AM
lights
the signal lights work, but they dont flash.
Old Oct 3, 2002 | 12:26 PM
deadbird's Avatar
Engine: TPI 305/ v6
If one side is working (flashing) inside and out and the other isn't. A bulb is out somewhere on the non-working side, there is a bad ground or your turn signal switch/cam is going south.
A single flasher relay is used for both left and right signals so, if it is working for one direction but not the other, the relay itself is good.
A good way to find burnt out signal bulbs is to turn the hazzards on and walk around the car.
Old Oct 4, 2002 | 01:44 PM
Morley's Avatar
Check the front marker lights, they flash with the signals.
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
thunder57
Nov 7, 2015 02:28 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lewandom
Oct 1, 2015 08:15 AM
