Gauge reading high voltage, . . . why?
Old Nov 29, 2001 | 02:37 PM
dowtyt's Avatar
I have an '83 Z with crossfire injection. I've had some real problems with it. The biggest one is that it idles at 2200 rpm, when it's cold, and it shakes during that period. I've replace the O2 sensor and the TPS, and it still spits out code 22-low voltage to TPS. I just noticed that the voltage on the gauge inside the car was nearly in the orange. It's been high for some time, but not this high. Do you think there is any correlation? Has anyone ever had this problem, and what are the chances it's my ECM? Sorry for the long post, but I desperately need help. thanks,
Tim
Old Nov 30, 2001 | 10:09 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Have you checked voltage at the battery w/a voltmeter? It could just be a bad gauge. Alternators are internally regulated, if there is a voltage problem, it will be with the alt., not the ECM. If the alt. really is putting out voltage in the red, it can fry the ECM.
I don't know squat about CFI except the TPS voltage should be .525±.o75v @ 400rmp (minimum air rpm).
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Aug 15, 2015 07:20 AM
