lady needing help
Old Oct 10, 2002 | 07:38 PM
tweetybird's Avatar
lady needing help
my passenger side window will not go down. i replaced (well not me actually) the motor thing in it about 6months ago, but now it doesnt make a noise or even try to go down. any suggestions?
Old Oct 10, 2002 | 08:57 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Have you checked the switch? The motor will not make a noise with out juice. If that is good, take off the door panel and see if there is something bent or broken. Good luck
Old Oct 10, 2002 | 09:04 PM
f0rmula350's Avatar
thats a nice car, yeh check the switch to see if its gettin juice.
tweetybird's Avatar
thanks i'll try
Old Oct 11, 2002 | 09:49 AM
Morley's Avatar
If there is no power to the switch...check the breakers for the windows (located in or near the fuse block).
Old Oct 12, 2002 | 07:01 PM
tweetybird's Avatar
there is juice at the switch. took off door panel and u can hear the motor trying to work (clicking noise) any suggestions on why it is just clicking? could the motor be bad again?
Old Oct 12, 2002 | 09:59 PM
Morley's Avatar
Clicking usually= stripped gears, I believe thay are plastic. Was this a brand new motor that was installed?
If it was then I bet that the felt covered guides for the window are way too tight and are stripping the gears.
Old Oct 12, 2002 | 10:43 PM
tweetybird's Avatar
yep it was a brand new motor. what would make the guides to tight? (probably the person that installed the motor?) thanks for the help
Old Oct 13, 2002 | 12:15 AM
Morley's Avatar
Yeah, whoever installed the new motor probably loosened the guides to slide the window up by hand to get at the motor mechinism. Then when they finished they got them too tight and that created a lot of drag on the window and stripped the gears in the motor gearbox.
You could loosen the guides for that window and see if the window will go up and down then.
Old Oct 14, 2002 | 07:10 PM
tweetybird's Avatar
for some reason after taking motor out of panel and putting back in, it started working. dang that was luck. thanks so very much for your help.
Old Oct 15, 2002 | 01:48 AM
Morley's Avatar
Were all the mounting screws/bolts there and tight? The alignment of that motor is critical, if one of the mounts becomes loose the motor will kick off to a side and just spin away.
Old Oct 15, 2002 | 06:43 PM
tweetybird's Avatar
not really for sure. but i think its right now. thanks again
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
