No Spark...not Ignition Module
Old Oct 22, 2002 | 02:07 PM
drummeraa1's Avatar
hey, I have a V-6 piece of sh*t...I want a better car but I have no money. I replaced the timing chain over the weekend, along with the plugs, wires, fuel filter. When I finished putting the front of the engine back together last night after finishing the timing chain, I took it for a test drive. It started right up...I drove it five miles, turned it off, started it again...everything worked fine.
This morning I went out to start it up, and it cranked strong but wouldn't start. After being confused for a long time, I checked one of the ignition wires to see if I was getting any spark. There was no spark. I had had this problem the same time last year and it was the ignition module. I thought it was weird that is would be bad already, but I put a brand new one in. Still, no spark...........I am really confused now.
By the way, the ignition coil and distributor cap are about a year old, but both look good. Any ideas???
Old Oct 22, 2002 | 05:41 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I would suggest testing the pickup and ignition coil with an ohmmeter for continuity.
A Haynes manual will tell you what kind of numbers to expect.
Try cranking the engine over with the distributor cap removed, have a friend check that the rotor and such are actually turning when you crank the engine over.
That's all I can think of for now...
Old Oct 22, 2002 | 06:05 PM
drummeraa1's Avatar
The rotor is turning. I figured out it is not anything in the distributor because I am not getting anything from the coil either.
Old Oct 24, 2002 | 11:49 AM
Nate1's Avatar
Car: 88 IROC-Z, 71 SS 454 Chevelle
Engine: 305 TPI, 454
Transmission: 5spd, th400
I had a similar problem and it was the coil.
Old Oct 24, 2002 | 02:24 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Have you checked for voltage at the coil ?
Old Oct 24, 2003 | 10:46 PM
stan-85-Z's Avatar
Car: 1985 Z-28
Where do you check voltage after the coil? Also, what kind of ohm readings should you get on the coil and pickup?
Old Oct 25, 2003 | 06:56 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
did u happen to disconnect the coil from the sparkplugs at any point and crank it? that will damage the coil, you need to ground it if u take the wires off the plugs, or not connect the coil to the distributor cap.
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
