transam headlights
Old Nov 16, 2002 | 03:04 AM
lunas's Avatar
transam headlights
ok, usually, if i trun my headlights on, even with the engine off, they popup. now after letting it sit for awhile, they wont pop up unless the engine is on. afterwards, they popup fine, even when the engine is dead, it only happens after i havnt used them in a while, anyone know whats goin on?
Old Nov 16, 2002 | 06:22 PM
lunas's Avatar
has this ever happened to anyone esle
Old Nov 16, 2002 | 06:55 PM
steve205's Avatar
ive had my bird for coming up to 4 years & aint had any problems with mine(seems to be the only thing i aint broke lol) , have u checked the batt, wiring , fuses ,headlamp motors ?
Old Nov 21, 2002 | 08:57 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The problem is the 3 gel inserts inside the large nylon gear that raises the headlight have gone bad. You need a headlight repair kit. I manufacture two versions which are on my web site. This kit only repairs the 1987-1992 units. The 1982-86 have a different headlight unit using 2 smaller gears.
Lon Salgren
Top-Down Solutions
TDS web site
There is still a slight glitch on my web site which prevents you from being able to register or purchase online. Just e-mail or PM me if you want to buy any item.
Old Nov 21, 2002 | 12:19 PM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
headlight problems too!
hi, all my fun revolves around my pass side motor. i bought a new one and it still dont work!plugged it in my dr-side ---then--fine!same with the old one,now,could it possibly be the relay is bad or are there two?one for each side???? HELP!!!! brad:hail:
Old Nov 22, 2002 | 12:37 PM
82tiresmoker's Avatar
Car: 82 Trans Am
Engine: 305 4bbl
Transmission: 4 spd
oh man, I thougt I was the only one with this problem, one side works, the other doesn't. Switching the "bad" stuff to the "good" side makes it work, and switching the "good" stuff to the "bad" side makes it not work. Is tehre some computer that controls these things?
Old Nov 23, 2002 | 09:08 AM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
i dont know.i researching the site for more info on them! my manual (chilton) says there are relays and such,but hopefully i can FINGER it out soon.....
anyone beable to help?????? thanks a ton!! brad
Old Nov 24, 2002 | 06:22 PM
2vmodular's Avatar
on 87-92 birds, the relays are inside the headlight door module
Old Nov 24, 2002 | 06:23 PM
2vmodular's Avatar
82'-86' birds use three seperate external relays:
Old Nov 25, 2002 | 09:43 PM
Nightcruzer's Avatar
Car: Trans Am
Use 2vmodulars diagram
https://www.thirdgen.org/techbb2/sho...threadid=73250
NZKnight
Oct 15, 2015 02:47 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
