Fog Light Mishap need help
Old Nov 22, 2002 | 11:24 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
some how the wires that connect to my fog light bulbs crossed and melted... now my fog lights dont work does anyone know if there is a fuse that could of blown, or a way to let me see light again???
Old Nov 24, 2002 | 07:13 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
did u install the fog lights yourself? if so, maybe you blew the bulbs? i dont think they would have a very high resistance.
Old Nov 24, 2002 | 11:25 PM
HamSpiced's Avatar
no man these are stock. the wires crossed and it fried one of them.
Old Nov 25, 2002 | 01:43 AM
kingrobert's Avatar
of the wires melted it would be my guess the fuse for the fog lights would have blown. to get them working again, replace the fuse and the wires, just wanted to ad my 2 cents
Old Nov 25, 2002 | 11:02 PM
HamSpiced's Avatar
ok then back to my origional question... is ther a fuse for the fog lights???if so where? is it an inline fuse cause i cant seem to find one under the dash....
Old Nov 25, 2002 | 11:17 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I don't rembmer exactly but, I think the fog lights are powered by the same circuit the marker/park lamps are on which is the 'tail' fuse I believe (?.. dunno the amprage fuse either). Anyways, if that fuse is blown then most likely your marker/park lamps won't be working either.
If the marker lamps are working, something further down the line cooked, i.e., the fog lamp switch, some more wiring you're not seeing or the relay (I'd guess the switch first but, that's just me... ).
Old Nov 26, 2002 | 12:16 AM
HamSpiced's Avatar
geeze...now on to bigger problems, and questions.. what relay controls the fog lamps and or where is the switch? pics would be exceptionally helpful.
Old Nov 27, 2002 | 12:04 AM
deadbird's Avatar
Engine: TPI 305/ v6
On a camaro, I'd assume somewhere close to the headlamp switch. I can't say where the relay is either, I don't have a car with factory fog lamps. Sort of worthless information, I know..
Old Nov 30, 2002 | 10:56 PM
HamSpiced's Avatar
i cant seem to find anywhere where i can rewire it... im completly stunned... ive checked all my fuses none are blown.....
Old Jun 11, 2003 | 06:19 PM
dunnb's Avatar
the fog lamp relay is by the washer jug behind the charcoal cannister
Old Jun 11, 2003 | 11:22 PM
HamSpiced's Avatar
thanks for the reply man....your like 6 months too late though... i found it, it wasnt a relay....
ther eis a small red wire that is spliced into a larger set of wires like a burn off wire that melted off when the wires grounded, while cleaning my engine bay i noticed it, replaced it and a fe wother wires and now all is good. thanks for the speedy responce
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
