Different Rear Defroster Question
Old Dec 3, 2002 | 12:00 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
i didnt want to ruin the other guys thread cause this is totally un related.
anyway my rear defroster works, but it doesnt stay on long enough to do anything. i find myself pressing the button 20+ times for it to do anything.. please tell me this is something simple and not a relay or an hour taking apart my car to fix..
Old Dec 3, 2002 | 11:54 PM
HamSpiced's Avatar
Please guys, i could use help here... its starting to snow and ice ove rlike everday..
Old Dec 4, 2002 | 01:42 AM
blackknight2010's Avatar
Car: 85 Transam
Engine: 305v8 carburetted
rear defroster
It does sound like a thermal trip circuit is kicking in ( safety circuit when it gets too hot )...I am guessing that your's does have this as part of the wiring...the relay / ballast is worth checking first which is located behind or below the passenger pouch & plastic trim, it should be easy to get to....hope this helps
Old Dec 4, 2002 | 05:47 PM
HamSpiced's Avatar
passenger pouch... maybe i should of given specs on my car. its an 89 camaro. what would the relay/ballast look like? got a part number if i need to replace it?
Old Dec 4, 2002 | 08:02 PM
Car: 85 Transam
rear defroster
Okay,your camaro interior will be without the pouch. Looking at the lower front dash trim from the passenger seat the plastic lower trim is held in by 3 or 4 screws normally. Press the on / off button & listen for the spring noise. The ballast is a long rectangular part, a bit like a bar of chocolate (but it don't taste so good) however don't replace it unless you have had it tested & are sure this is the fault, there are so many capacitors,relays etc these days.
Hunting for electrical probs can be a nightmare. Back in May, I had a problem with my pop up & rear lights not working. Tried the switch, wires, relays, I even went to an electrian but as soon as he saw it was an american car he ran away. In the end, I spent over 7 & a half hours tracing back every curcuit till it turned out to be an intermittant bad wire behind the fuse box.
Old Dec 4, 2002 | 11:17 PM
HamSpiced's Avatar
ouch man that sucks...
ok i pressed the defrost button and listend... only spring thin gi heard was directly behidn the switch i pressed.. does that make any sense.. that default temp switch sounds liek what would be the prob. is that what i am searching for????
Old Dec 5, 2002 | 01:26 AM
Car: 85 Transam
rear defroster
your default temp switch might be worth a look...I had an 84 camaro berlinetta a few years ago, I thought the circuit layout was the same...well,sorry I couldn't be any more help....good luck
Old Dec 5, 2002 | 03:40 PM
HamSpiced's Avatar
ok so back to my question... wheres the defeault temp switch at???
Old Dec 5, 2002 | 04:54 PM
Car: 85 Transam
rear defroster
I really can't say as my old 84-85 camaro would be different as it had the digital dash & micro push switches (i believe this was the only year they did this ), my pontiac must be different too.
Sorry I can't be of any further help. Good luck.
Old Dec 5, 2002 | 08:27 PM
HamSpiced's Avatar
well.. whats it look like? have apic? how much does it cost to replace?? i want to get this done soon....
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
