Stupid and need help ha
Old Dec 21, 2002 | 11:15 PM
jdrafke's Avatar
um well thanks guys on the blinker problem. i replaced the flasher unit and whaa la it worked. Sweet! but yea when i turn on the headlights the green arrow for the right signal stays on solid and when i turn to go right it flashes but it wont shut off. can anyone tell me how to fix this thankx
Old Dec 21, 2002 | 11:16 PM
jdrafke's Avatar
add on
its on the control panal that it stays on solid.
Old Dec 22, 2002 | 12:34 AM
MdFormula350's Avatar
usually when it stays constant and doesnt flash it could be a bulb.
Old Dec 22, 2002 | 01:07 AM
Morley's Avatar
Yep, a bad bulb, socket or wiring for a light on the side that is acting up.
Old Dec 22, 2002 | 11:36 AM
jdrafke's Avatar
well yes i have replaced all three bulbs and still the light stays on. what wiring should i check?
Old Dec 26, 2002 | 11:06 PM
racerx004's Avatar
Is it that just the little green light stays on, or do the lights behind the gauges get dim, and your gauges go screwy?
I had a similar problem, turned out to be the printed circuit board behind the gauge cluster.
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
