torque converter lock up, and temperature wireing
Old Dec 26, 2002 | 05:40 PM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
ok, all i really need to know is what side of the firewall (passanger or driver) the temperature sensor wire is suppost to go into (or out of). and what do i have to do to lock the torque converter up? do i have to ground(or apply power to) one or more of the wires comeing out of the modual at the back of the tranny? and how will i know if its locked? will it click? or does the car have to be moveing for it to lock up? i have one green wire comeing out of there that doesnt go anywhere and if i apply power to it, it sparks, if i ground it, it does nothing. and there isnt any power comeing out of it.
Old Dec 27, 2002 | 08:17 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Temp guage sender wire is a single green wire located at the sender unit which is normally bet cyls 1&3 on driver side. grounding that wire should peg the guage. you can lock the conv at any time but if its idleing it will stall the vehicle. go to this site www.technicalevolution.com. Ken has an article on how to lock up 700-r4 boxes on non ECM vehicles.
Old Dec 27, 2002 | 12:58 PM
Psyte's Avatar
uhhh.... i looked around for quite a while and i didnt see anything on that page that mentions how to lock the torque converter up. there is plenty that tells how a torque converter works though.
Old Dec 28, 2002 | 01:34 AM
MdFormula350's Avatar
maybe try this https://www.thirdgen.org/newdesign/t...ueswitch.shtml
Old Dec 28, 2002 | 06:26 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
http://www.technicalevolution.com/700inst.htm
Old Dec 29, 2002 | 01:37 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Here is a Automatic Lock up
http://www.700r4.com/Tech/TCC/
Old Dec 29, 2002 | 02:27 PM
Psyte's Avatar
i do understand how a torque converter "should" lock up. i removed my ecm, so if i go by what that tech article here on third gen says, will it still lock up?
Old Dec 29, 2002 | 03:13 PM
DTL504's Avatar
No its Bogus information just to confuse you...
Yes that the reason it there, BECAUSE IT WORKS
Old Dec 29, 2002 | 08:43 PM
Psyte's Avatar
relax buddy, it was a simple question. as far as i knew the asdl was ecm based.
Old Dec 30, 2002 | 11:23 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
As long as you have the wires and the connector still going to the tranny then you can still rig up a switch to manually lock-up the TC. I'm currently experiencing a brain fart, but one of the wires (of 3) just has to get 12 volts, via a simple switch.
And also, no the car will not stall when the TC is locked, it shouldnt ever lock while its in 1st gear, only 2nd through OD. Besides, when your city crusin, you dont need to lock the TC, it just makes for better mileage on the highway.
Old Dec 30, 2002 | 11:34 PM
DTL504's Avatar
Matbe this wil help:
http://www.700r4.com/Tech/TCC/GM_Switch.htm
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
gwade12
Aug 8, 2015 08:17 AM
