Turning signal/blinkers
I just installed a new battery and new starter. Now for some reason, my turning signals do not work properly. They come on solid, as do the dash board light arrows. They are solid.
Checked the fuses, and they all look good.
Any ideas?
Joshua Zimmerman
1986 Camaro that is getting a lot of work done to it.
Any ideas?
Joshua Zimmerman
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Only because he's using everything in the plural sense.. I'd guess the flasher relay took a dive... that's just me though...
Easiest way to check for burnt out signal bulbs it to turn on your hazzards and do a walk-around.. they will flash regardless of burn out bulbs.
83 Crossfire TA
Sep 8, 2015 12:06 PM
