brake lights not working!?
Old Dec 30, 2002 | 01:02 PM
600_dollars's Avatar
Okay .. well i have noticed no brake lights any obvious problems that i should be aware off? .. its a 1984 Trans am with a 350 ..
Old Dec 30, 2002 | 01:22 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Absolutely no brake lights could very well be the brake switch. It's mounet on the brake pedal bracket inline and above the brake pedal. You'll most likely need to remove the underdash trim to see it. There should be an orange and (light) blue wire plugged into it. The orange should have +12v constant, if not, check the 'stop' or 'haz' (something like that anyways) fuse and, the blue will have +12v when the brake pedal is pressed. If it doesn't, the switch is bad
Old Dec 30, 2002 | 10:12 PM
MdFormula350's Avatar
http://92b4crs.tripod.com/86wiring/dia-pics/110-2.jpg
1986 camaro diagram might help..
http://92b4crs.tripod.com/86wiring/86wiringindex.html
Old Dec 30, 2002 | 10:42 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Do the park lights still work? What I mean is, when you turn the headlights on, do the rear lights light up? Have you tried changing the bulbs? Other than that, Deadbird is probably right.
Old Dec 31, 2002 | 10:15 AM
My tail lights work , the reverse lights work.. all fuses have been changed , but NO brake lights got its pissing me off and someone almost rear ended me
Old Dec 31, 2002 | 12:07 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Did you put dual element bulbs in, or have you checked yet.
Shouldnt be driving around with no brake lights.:nono:
Relax, we'll get it worked out. Just lets us know what you have done so far.
Old Dec 31, 2002 | 03:04 PM
deadbird's Avatar
Engine: TPI 305/ v6
The brake lights and parking lamps are on 2 completely circuits.
Even if you put in single element bulb, the park lamps would now just be as bright as when you hit the brakes instead of having a high/low elements.
The brakes are a simple circuit, power to the switch, switch to the stop element in the bulb. I'm sticking with my switch theory (especially since I just replaced mine last week ). You can aquire a switch from any major chain part store for around $10, not an expensive variable to eleminate. It takes roughly all of 5 minutes to replace, if the underdash trim isn't there, just under 1.5 minutes.
Old Jan 2, 2003 | 10:24 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
One time I changed the bulbs out in the rear and forgot to push in and twist clockwise (dont ask me how), only the park lights would come on and no brake lights. That had me stumped for a minute, then I beat myself over the head with a jack stand once I realized what it was.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
