car stalling... not starting... then running fine!!! HELP
Old Jan 2, 2003 | 02:05 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
PROBLEM: last few days driving the car it occasionally acts like it wants to stall and die... kinda like the engine stalls... but it doesn't... just barely... that was until last night... driving home... it did its half stall thing... then a mile down the road it died... i pulled over... tried to start it... i had power, started turned... engine rolled over... but no go... thought it might be the fuel pump... cause it didn't seem to be priming like usual... but then it started to prime and started after like 10 minutes... and it was fine until my next stop... then it did it again later that night... same thing... stopped.... off for a while... then start and go.... but it finally stalled and didn't start... i left it and came back this morning... started with no problem... i am guessing i have either an ignition problem, or a gremlin in the harness... something to do with the fuel relay or wiring...:confused
Old Jan 2, 2003 | 07:04 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
first check the easy stuff, ive known people that had the same problem and it was only a clogged fuel filter. when it does it check to see if you have spark. then get into the hard stuff.
Old Jan 3, 2003 | 01:47 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
i would have thought fuel filter too... but i replaced it last week... but i think i figured out the problem... bad ignition module... replaced it and the coil and the thing has had no problems...
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Old Jan 6, 2003 | 12:04 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
well dang... replaced the module and coil hoping that was the problem... but no go... the car still is starting, running, cutting off, then starting and running fine until it decides to shut off again... i still have full power... but the engine just shuts off... any other guesses
Old Jan 6, 2003 | 04:58 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Sounds like possibly the fuel pump or loss of voltage to it. Check the fuel pressure, it might give you a clue.
Old Jan 6, 2003 | 06:00 PM
BOTTLEDZ28's Avatar
Transmission: A4
mine does the same thing. just shuts off while driving. I havent been able to figure it out but I think it may be due to the fact that my speedo isnt hooked up.
Old Jan 15, 2003 | 12:20 AM
evelkneivel001's Avatar
Car: 87 GTA
Engine: 383 Stroker
Transmission: 700 R4
cutting off problems
My 87 was doing the same when I finally sent it to a garage. I feel as if I've sinned. I do all the mechanic work and I've went through the car and replaced everything you can imagine. Anyway, come to find out, the distributor went bad. When I say went bad I mean that oil made its way past the shaft that drives the rotor and filled the cap with oil. $300 and a lesson learned. Hope this helps. My car only has 115k and this was the last thing I expected. No oil ever even dropped on the pavement.
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
