dead (single) ele. cooling fan
Old Jan 19, 2003 | 01:04 PM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
my electric cooling fan (1) just stopped working!(90 formula tbi 336- just like the blue one above) i looked at the fuse block--ok! could it possibly be a fan relay-somewhere? how could i test it???what other possibilities are there besides what i have mentioned??? please help guys!!! apprerciate it!!!!! fellow 3rd gen heads!!!! brad:hail:
Old Jan 19, 2003 | 01:27 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
It's possible that the relay has failed, it happened to me but under, shall we say 'unusual' circumstances.
I would test the fan by itself first. Unplug the fan connector and apply 12 Volts DC from a safe source like a small battery charger or the likes.
In my case a soldered connection inside the relay went open from heat. They are fairly heavy-duty relays, so they should survive many years of use.
Old Jan 19, 2003 | 01:58 PM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
on the hunt...
thanx rustydawg! i will buy a new one probably from napa tomorrow for 14 dollars....ill let ya know the progress! also im trying to get my hands on a fan switch that turns on @ 200 deg and off @ 185 deg too.,but could i stay with the stock 195 thermo with this combo, is the next issue-isnt it? couldnt be a bum original fan switch -could it?---well ill do the relay FOIST........ watch this space-
ps also have a "tbi chips.com" custom eprom also.....................brad
Old Jan 19, 2003 | 02:59 PM
MdFormula350's Avatar
i dont really how the fan would come on before the stat opens..
like i run the stock 195 and my fans hardly even come on at all..
Old Jan 20, 2003 | 08:18 AM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
Go to autozone and get you a fan switch for a 1991 C-4 Corvette 5.7 liter..autozone part number is #36669 and cost is $16.99 plus tax....comes on at 200* and goes off at 185*... then drop in a 180* stat.... if they dont have it in stock it needs to be ordered....also if you want you can buy you a new electric fan motor also from them....$34.95....just a couple fo bolts to change out....good luck.......
Old Jan 21, 2003 | 04:10 PM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
cooooooool bro!
hey ultra-mega thanx,BUD! i am going to do just that! next:tracking autozone down!!! hehehehe brad
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
