Left headlight won't work with low beams
Old Jan 20, 2003 | 09:59 AM
RallyRedTexan's Avatar
Car: 92 RS
Engine: 5.0 TBI
Transmission: A4
Hi, I'm Robert and I have a 92RS. My left low-beam will not work when the low-beams are on but works fine when all four light up for the high-beams. I need to know where to start and what the problem may be.
Thanks your help in much appreciated,
Robert
Old Jan 20, 2003 | 10:29 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
You most likely just need to replace that headlight..They work daul purpose. Like a trun signal kinda..has a double fillement idea..Replace the light, and you should be fine..If it makes you feel better, pop your hood, and check all the connections quickly for corrosion or a broken wire. Most likely you just need a new headlight though.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Fronzizzle
Aug 9, 2015 01:15 PM
