Power hatch release problems!! help
Old Jan 25, 2003 | 12:36 AM
Fastcamaro87's Avatar
ok heres the problem, my power hatch release wont work if the parking brake is not up, the switch makes the parking brake light come on when you press it but it doesnt pop the hatch, when the parking brake is on the hatch release works fine. any ideas as to what it could be? not a major problem but definitely annoying. i havent gotten a chance to get in there and see whats goin on yet, but i figured maybe some of you guys have had similar problems , or could give some help on what to look for.
thanks
Matt
Old Jan 25, 2003 | 09:59 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
On manual transmission cars, the hatch solenoid release will work all the time if the ignition switch is off. With the ignition swtich on, it will only work if the parking brake is pulled up, (as you are describing). On auto equipped cars, if the ingition is on, the gear selector must be in P or N (it is tied into the Neutral Safety switch). This is a safety feature so you won't pop the release while driving. I can send you a scan of the wiring diagram. I could tell you how to defeat the safety feature, but do you want to risk popping the hatch at 70 mph?
Lon
Old Feb 2, 2003 | 02:41 AM
sllt1776's Avatar
Car: 89 Iroc-Z
that's right..so is the car off or on when your trying to pop the hatch. if it is off then you have a wiring problem. start at that saftey circuit.
Old Feb 2, 2003 | 02:44 AM
with the car off i have to put the handbrake on to pop the hatch, same when its on.
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
neekolzun
Aug 24, 2015 04:59 PM
Bert87
Aug 23, 2015 03:50 PM
stalkier
Aug 13, 2015 12:59 PM
