140 amp alt
Old Jan 23, 2003 | 05:13 PM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
140 amp alt
Hey guys who makes a 140 amp alt for firebird/camaro's......will I be able to get one for a 1992 Firebird LO3 TBI, also what other cars did this alt come in and will it bolt right up.....my stock one is on the way out and Id like to get a higher one for audio purposes
Old Jan 23, 2003 | 07:34 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
search for "iceberg"
Old Jan 24, 2003 | 12:01 AM
mrbboy's Avatar
I just installed a PowerMaster 140 amp alternator in my 91 RS. I got it from summitracing.com.
Old Jan 26, 2003 | 10:52 AM
dsaint1347's Avatar
tell Mrbboy have you seen an improvement in charging at all, like how is it on idle.
Old Jan 26, 2003 | 06:55 PM
mrbboy's Avatar
I installed this alternator because I had a massive power drain when operating my rear defroster, stereo, heater, wipers and headlights (H4). I tested the alternator output even whith all these accessories running and it stays steady at 14.7 volts. One other thing I noticed is that my idle feels more stable too. Everything worked great.
Rene
Old Jan 26, 2003 | 09:46 PM
dsaint1347's Avatar
Looks like I am buying a new alternator.
Old Jan 31, 2003 | 06:32 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
www.alternatorparts.com. They are selling new GM 140 amp units that came with the BC4 package for under $200.
Old Feb 2, 2003 | 12:01 AM
radiateu2's Avatar
hey Danno I purchased the iceburg up grade for my alternator I hope it helps with my idle issues. The car runs like cr@p now I think its from the drain on the battery. By the way isnt it true that that once the car is running the engine draws its power mainly from the alternator?
Old Feb 2, 2003 | 08:00 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Think of the alt as piggybacked to the battery. The battery is the heart of the system, that's why it is so important to start with a fully charged batt. The alt maintains the battery at a level of charge as electrical demands vary in the vehicle. The vehicle does not run from the alt per se, the alt simply replaces capacity to the batt. I have done several iceberg kits, it's kind of early to know whether or not they prolong the life of the rear bearing or not. Considering what a GM reman unit sell for I believe it is very cost effective to do your own rebuilds.
Old Feb 2, 2003 | 09:42 AM
Vader's Avatar
Re: 140 amp alt
There's a little company in Flint, Michigan that sells them. I think their name is "General Motors", or something like that. One of their sidelines is alternators. I've got a couple of them, and they work just like the originals.
HINT: If you have an audio amp with a high peak output, a large capacitor may solve many of your problems. I've seen a one Farad (friggin' huge) installed on even smaller ŕcers that solves many peak power problems.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
