want to replace battery to the top terminal round thingys
Old Feb 3, 2003 | 10:14 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
yea, i cant remember the name of it, but i want to replace my battery with one of the batteries that has the round terminals on the top of the battery. i was wondering if anyone did this and how considering my current battery is the side moutn ones with that stupid round thing that is held on with a little screw. anyway, anyone done this??
Old Feb 3, 2003 | 02:21 PM
Jza's Avatar
Jza
Easiest way is to replace the battery wires. One goes to the big lug on the starter and the other goes to a ground on an engine bracket. Doesn't get any simpler than that.
But why? The side terminals are better. I'm gonna guess and say you stripped them or rounded off the bolts.
Two tips:
1) They don't have to be super tight, just snugged.
2) Don't tighten them with a wrench. Just use the wrench to get them snug, then use some pliers around the round part to actually give it a little torque. If you feel you must tighten them with a wrench, use a 5/16" 6-point, never a 12-point, and definitely never with a crescent wrench.
or.. you can get a Snap-On 5/16" GM Battery Terminal wrench and never have a problem again.
Old Feb 3, 2003 | 03:11 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
I changed mine....but I had to because you can't get hold of the screw terminal batteries in this country.
As the Jza said, I replaced the battery cables...although I didn't do the whole cable, just some cable extention with round terminal connectors on the ends. Clamped them good and insulated them well, and all is fine.
Couldn't give you any pros and cons for you doing it, as I don't know availabilities etc over there, but as I said, I really didn't have a choice!!
Si
Old Feb 3, 2003 | 04:58 PM
HamSpiced's Avatar
i wanna change cause mu amp wire si all big and it offsets the giant round red thing that screws to it, if i get the top mount battery then i can just hook one of them clips to it. and there are some top mount connects for my amp rather then just a ring terminal.
Old Feb 3, 2003 | 05:09 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
howbout getting a battery with top and side posts? i run main wire to the sides and all my accessories to the top posts (4ga amp lead, msd6al, fog lights, etc) with one of those brass distribution block things...actually looks pretty clean that way...otherwise it'd look like an overloaded outlet...
Old Feb 3, 2003 | 05:26 PM
HamSpiced's Avatar
ive never seen that type of battery.. cause i can get the single top mount ones for free.
Old Feb 3, 2003 | 05:50 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
si_camaro
You certainly can get the side terminal batteries in the UK!
I just bought one for £59. Tell me if you ever want one!!
Andy.
Old Feb 4, 2003 | 01:09 PM
si_camaro's Avatar
Car: 85 Z28
Thanks for the info, Andy...I didn't know that!
I run a parts and accessories shop though and can get heavy duty round post batteries for £15...but thanks anyway...
Si
Old Feb 4, 2003 | 01:19 PM
Car: 91 camaro rs
Hi si.
No problems with that. I couldn't get a heavy duty battery that would fit in the "hole" in the battery panel. They were either too long, too wide or too tall!! The closest one was £61, but was too wide. I was amazed when he offered me a side terminal one with the exact dimensions of the old one for the next day. If you want I can find their suppliers as a matter of interest.
£15 is too damn good!!
Hows the resto going?
Andy.
Old Feb 4, 2003 | 03:43 PM
si_camaro's Avatar
Car: 85 Z28
A supplier would be interesting, maybe I could get some in for the shop...I'd like to get some specialist parts in there because there are a few enthusiasts in my area.
The resto is plodding on. I'm practically ready to put the engine back together now, all I need is a head gasket set and some time away from this hole I call married life. I'll be borrowing a digital camera from a friend soon, and taking some pictures of the newly worked heads and intake. Maybe I'll find time to put them on the website too!
Si
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
