msd engine knock alert have you used one?
Old Feb 8, 2003 | 07:38 PM
CrashedMatrix's Avatar
has anyone here ever used the msd engine knock alert. How did it work? I was thinking of buying this and using it with my msd btm for my blower setup.
Old Feb 10, 2003 | 02:37 PM
Jza's Avatar
Jza
Are you a DIY type of person? (Like can follow an electric circuit diagram and assemble a simple circuit board?) If yes, then I might dig up the schematics for a simple knock indicator found either here or on diy-efi.org. Only if you're damn serious though (because there's serious digging involved).
Old Feb 10, 2003 | 10:51 PM
Yes im a diy person espically electronics I build many printed circuit board types of things all the time! Im very intrested in what you have!
Old Feb 11, 2003 | 08:30 AM
Jza's Avatar
Jza
Alright, I'll look for it when I get home.
Old Feb 12, 2003 | 10:17 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3.73 posi
Jza
I am also very interested in this "homemade" knock detector circuit if you manage to find it.
Thanks in advance
Old Feb 18, 2003 | 09:00 PM
any luck find the info?
Old Feb 18, 2003 | 10:00 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Ditto. I'm still interested as well in this knock detector circuit when/if you find it.
Old Feb 18, 2003 | 10:44 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm interested too
please find it....it will compliment my homemade AIR/FUEL guage I built.
Old Feb 18, 2003 | 11:47 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Originally posted by xpndbl3
i'm interested too
Interesting xpndbl3, I was just searching the boards to find if someone has built what you say you already have done. Do you mind filling me in on a few details on what components you used to make your AF gauge. Did you have to build a circuit board to translate your V readings from your O2 sensor into an output signal to a series of LEDs? This is all that I suspect is behind any of the aftermarket AF gauges.
Appreciate your input
Old Feb 21, 2003 | 01:49 PM
Jza's Avatar
Jza
Found it.
This uses your existing ESC module to take care of the filtering and simply interprets the signal to the ECM to alert you of knock. But because of this I don't think it'll work with 90-92 SD setups. Haven't played with it, though (yet). There's some bloatware in there too, but it's all good.
http://www.gnttype.org/techarea/projects/knock/
Enjoy.
Old Feb 22, 2003 | 04:25 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Thanks JZA for the info! Much appreciated.
Old Feb 23, 2003 | 02:40 AM
xpndbl3's Avatar
Car: 1984 Z28
Well for the homemade A/F ratio I used a standard IC chip LM3981....i "think" If you go to deadbird's website, he's a member of this board he has the diagrams on there.
www.deadbird.org there in there somewhere
Steve
Old Feb 23, 2003 | 01:04 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
I managed to find some info on the A/F meter but I will check out Deadbirds info as well. Thanks for the help!
toronto formula
Nov 10, 2015 06:17 AM
db057
Aug 22, 2015 08:17 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
