Buzzer sounds bad when i put the key in
Old Feb 10, 2003 | 06:50 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
You know the buzzer that sounds when u leave the keys in the ignition? i think that switch is making a bad contact and makes my buzzer sound like a dying animal. if the buzzer is sounding because of something other then the key, like the lights being on, it sounds fine. so im pretty sure its just a bad contact in the ignition. what do i clean off to fix this?
Old Feb 10, 2003 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As strange as it sounds, I had a similiar problem with a very worn key. I used a new spare one day and the problem was 'solved.'
JamesC
Old Feb 10, 2003 | 02:52 PM
TekViper's Avatar
Engine: 3.1L v6
makes sense i guess, key gets worn and slightly smaller, probably not making full contact. how much is a spare key from a dealer that has the VATS resistor thing on it?
Old Feb 11, 2003 | 12:15 AM
FLYNLOW92rs's Avatar
I've seen them anywhere from $30 - $70
Shop around and call dealerships to get the cheapest price....
Old Feb 12, 2003 | 08:41 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
why dont you get one cut? for a buck...
Old Feb 12, 2003 | 08:48 PM
TekViper's Avatar
Engine: 3.1L v6
because my key has the VATS on it. if i got a duplicate key without it, it wouldnt work unless i bybass the VATS. are there places that do keys with the resistor already in it?
Old Feb 12, 2003 | 09:31 PM
Car: 1984 Z28
i doubt it.. you will probably have to go to a GM dealership. unless you can pay extra for a locksmith* to get one.
* = if that would be a place to get keys cut
Old Feb 26, 2003 | 12:59 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
i believe you can buy an uncut key with a selected resistor from Ecklers.com and they just take it to wal-mart and have it cut.
Old Feb 26, 2003 | 01:06 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
here it is from ecklers.com
Part# A9129-1
1986-96 Ignition Key VATS Code 1
$14.99 EA.
Quantity Needed:
Specially Coded
Because 1986 and later Corvette have specially coded ignition keys, it makes good sense to have a couple of spares. To order a key, have your local GM dealer measure the resistance on your key (it will be a 1 thru 15 value code) and add that code to the part number A9129 (i.e. A9129-1, A9129-5, etc.).
Old Feb 26, 2003 | 08:15 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Try just sticking any other key in and see what happens. Just as long as it's a GM key. It doesn't have to be one for your car (remember, you don't have to turn the key for the buzzer function).
Also, another idea. Sometimes, there are two separate buzzers in one module. One for the key, and one for headlights. you can tell these by opening the door with the key in, and by turning on the headlights. If there are two buzzers, you should be able to hear them both. In that case, it would mean one of the two buzzers is getting bad, or a bad connection.
this is kinda OT, but buzzer related, so I'll ask here. Does anybody know of a replacement buzzer that makes a different sound? I find the ones that are more of a chime, or an intermittent repetetive "bing" sound to be much less annoying than the buzzer, but I've never bothered to try and replace it.
Old Sep 14, 2005 | 01:11 PM
85_ZED28's Avatar
Car: '85 Z28
sorry for digging up an old post, but I am also searching for an answer to this ^^
anyone know of a more pleasing chime that will fit right in?
Old Sep 17, 2005 | 10:38 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
You can have my buzzer it sounds like a dying cat in heat.
Old Sep 17, 2005 | 10:39 PM
bobdole369's Avatar
Car: 1989 Firebird
Back on topic, if I recall, the buzzer is activated by a +12V signal. Just find it, and replace with a light, or a different buzzer. You could make something yourself, just need a 555, an op amp and some caps and resistors and a speaker.
Old Sep 18, 2005 | 02:41 AM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
My buzzer doesn't work at all. Any idea where it's hidden at so I can replace it. It's not like I can follow the sound.
Old Sep 18, 2005 | 10:24 AM
Vader's Avatar
The warning chime on a Firebird is located on the Convenience Center. This is a small panel that swings down from under the dash in the far right side of the driver's lower bolster, just to the left of the radio pedestal. The chime unit is plugged into that.
However, the chime unit relies on an input from the contacts in the steering column. If the contact in the steering column is marginal, a new chime unit may act just the same.
A new key may or may not solve the problem, since wear in the lock cylinder itself may contribute to the problem.
A new VATS key can (with cut) be had at a locksmith for $9. They used to be about $7, but prices are increasing. Dealerships are about three times that price. Periodic lubrication of the lock cylinder (and all lock cylinders) with graphite (DON"T use anything but graphite) will prolong its useful life.
Old Sep 19, 2005 | 12:36 AM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
Thanks vader, I've been trying to find the stupid buzzer for a while. As much as I hate hearing the noise, I like knowing when I leave my dims on, when I leave the car.
Old Nov 7, 2005 | 08:55 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
It is called SILENCE. Yank the buzzer at the base of the column and no more problem.
Old Nov 7, 2005 | 08:59 AM
Jetmeck's Avatar
A new key may or may not solve het problem, since wear in the lock cylinder itself may contribute to the problem.
Exactly right and when changing out lock cylinders you can KILL the buzzer by removing the Clip looking thing that snaps in place just below and at the inboard end of lock cylinder.
Old Nov 7, 2005 | 03:12 PM
85_ZED28's Avatar
Car: '85 Z28
It is called READING POSTS CORRECTLY. I don't want silence.
Old Nov 7, 2005 | 04:05 PM
Jetmeck's Avatar
Calling me an idiot, you are the one wanting the door buzzer to sing you a song. You are probably all of 21, go F yourself and next time you call someone an idiot you might duck. Jerk...took the time to type a smartass comment...no other name for people like you. How many other comments telling you to disconnect the damn thing and shut up ?
Old Nov 7, 2005 | 05:00 PM
85_ZED28's Avatar
Car: '85 Z28
Maybe you should have shown me respect in the first place and not given a smartass answer to a question I didn't ask. I'm a jerk? How did you expect me to react?
lol
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 12:07 PM
