Who makes the best headlight switch replacement?
Old Feb 20, 2003 | 10:11 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
ARGH!!! The dash light dimmer in my headlight switch burned out and now my dash lights are OUT. When I turn the **** all the way up to turn on the dome light, the dash lights come back on, so it's not a blown fuse or broken wire. So... who makes the BEST replacement? Please note that I replaced the 194 bulbs in the cluster with brighter 168s, so that may be why the thing failed. I guess I'm looking for a switch with a dimmer that can handle the extra load. Suggestions? Thanks!
Old Feb 22, 2003 | 02:54 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
obviuosly acdelco is the best, but then standard comes on a close second.
i have used both, and both are good, with the delcos quality being a little better.
good luck
thanks
anthony
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tnrednneck
Aug 13, 2015 08:57 AM
Fronzizzle
Aug 9, 2015 01:15 PM
