Temp gauge problem
Old Feb 26, 2003 | 10:56 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Temp gauge problem
I just had my inst cluster out in order to change the headlight switch. Now that it's all back together, the temp gauge is intermittent. When it's COLD in the car, the temp gauge doesn't work. After the interior warms up, it starts working again. Did I damage the cheezy-assed PC board by handling? Broke a connection? I thinking of pulling the cluster again and retouching all the solder joints and cleaning the contacts where the cluster plugs into those dash connectors.
Suggestions? Thanks.
Old Feb 26, 2003 | 11:23 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Does the gauge sweep alright when cranking the car to start ?
I'd make sure the connector at the sender was clean and tight 1st and then maybe spray some lithium grease on the even cheezier-arsed made gauge and put some di-electric grease on the printed board harness contacts (on the cluster) to assure good connections. The sender cold also be getting ready to take a dive. Just some thoughts, none gaurenteed to be correct though
Ghettobird52
Jul 5, 2024 11:18 PM
Bstrang6
Sep 8, 2015 04:29 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
