Dash Board Grounds
Old Mar 4, 2003 | 08:54 PM
Mark W. Winning's Avatar
Dash Board Grounds
I just installed a new dash board in my 85 Camaro. Now the lights for the insterument cluster do not work and the gauges do crazy things. I figure I missed a groud wire or two, but have been unable to find them. Any ideas???
Old Mar 5, 2003 | 06:06 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I only noticed two underdash grounds on the 85 Camaro harness I put in my friends truck. Most of the grounds are tied into a single ground wire and then I believe the headlight switch ground.
One cause of the problem could be the cluster is not getting good contact with the harness plugs (i.e. dirty contacts).
That along with the cluster loosely mounted causes a similar reaction in my friends truck. The tach will jump, volts misread, certain lights light up etc..
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
Stryker412
Sep 7, 2015 09:11 AM
andy74
Sep 3, 2015 08:41 AM
