Can you have hatch switch and outside relase?
Old Mar 20, 2003 | 01:41 PM
skahide's Avatar
I have a 88 camaro with a hatch motor, but had no inside relase button. I ordered a button, harness, and silonoid from ebay and recieved it today. I got all the wiring set up and then went to hook up the silinoid. I have seen pics of how to hook it up but because i have the hatch motor it dosent hook up the same. Is there anyway to put both the inside switch and outside lock to work at the same time without haveing to rewire?
Old Mar 20, 2003 | 02:15 PM
smokingss's Avatar
ska...u happen to have a pic of the parts you bought, that way i know what u have to work with and i could help you probably
Old Mar 20, 2003 | 04:31 PM
skahide's Avatar
This is the silonoid i have.
Attached Thumbnails Can you have hatch switch and outside relase?-mvc-328f.jpg
Old Mar 20, 2003 | 04:40 PM
skahide's Avatar
Here is the setup i have now that unlocks from outside
Attached Thumbnails Can you have hatch switch and outside relase?-mvc-331f.jpg
Old Mar 20, 2003 | 04:46 PM
skahide's Avatar
PIC #2
Attached Thumbnails Can you have hatch switch and outside relase?-mvc-330f.jpg
Old Mar 20, 2003 | 04:48 PM
skahide's Avatar
This is the silonoid in the first picture, but placed so that the inside button would work. But with that setup you cannot use the lock from the outside.
Attached Thumbnails Can you have hatch switch and outside relase?-mvc-333f.jpg
Old Mar 20, 2003 | 04:51 PM
smokingss's Avatar
ok , now that i know what your working with i'll go through my parts and cars and see how its done, i know all cars that had the button release were also able to open it with a key, ill see how and ill get back to ya tomorrow. -Paul
Old Mar 20, 2003 | 05:06 PM
skahide's Avatar
I think this is what i need(the silver peice). Where can i find it? Auto store, junkyard? thank you Paul
Old Mar 20, 2003 | 05:13 PM
skahide's Avatar
sorry double post
Old Mar 20, 2003 | 05:19 PM
skahide's Avatar
sorry tripple post
Old Mar 20, 2003 | 11:10 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
There should be a cable going out of the black piece that goes to the lock cylinder. If you didnt get that piece, then you might have to graft your old one on to the new one. I'm just not sure if you can do that. I can look tomorrow.
Old Mar 20, 2003 | 11:16 PM
smokingss's Avatar
little back cable with a white ring on it that connects to the lock cylinder, ah i know the peice i saw it this afternoon on my wrorbench, ill post pics and explain tomorrow, its late now
Old May 31, 2003 | 12:56 PM
89FirebirdJV's Avatar
When I bought my car the power trunk didn't work so I replaced it. I bought a switch for the dash that releases it (which I didn't have) and connected it. And it still doesn't work by the switch. It will work with the key. Does anybody know what could be the problem. The light on the switch comes on when I turn on my light so I know there is power going to the switch. I believe the #11 fuse controls the Hatchback lid release. Does anybody have any idea about how to fix this problem. I don't want to half to go to GM.
Old May 31, 2003 | 06:01 PM
skahide's Avatar
so all you added was the switch? not a silinoid? when adding the inside access you must add the silinoid and switch. i have the parts to add only the inside switch but not have an outside access. ill sell it to you really cheap but like i said you wont be able to open from key, only the button.
Old May 31, 2003 | 09:40 PM
But I do have the silinoid because there is a black cable the goes to it I will get pictures up so I can show you what my power trunk looks like
punkmaster98
Sep 30, 2015 11:01 AM
Randomtask2
Sep 10, 2015 08:37 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
scottmoyer
Sep 7, 2015 07:06 PM
2012sergen11
Sep 7, 2015 11:37 AM
