Dead starting
Old Mar 23, 2003 | 08:15 PM
MustangMuncher's Avatar
Car: 89 Camaro
Engine: 355
Transmission: Coan rebuilt TH700R-4
Dead starting
I have a 89 rs and the cylinder ignition has already been replaced along with the alternator and about 3 starters. Sometimes when I try and start the car after a run in town the motor wont even turn over and everything will stop as if it were trying to start, radio, cooling fan, etc. but nothing will happen just silence. At first I thought it was the starter from heat shock but I have a shield on it now and the alarm system has been taken off. The wierd thing is that if I jump it from another car it will start so its telling me that I have a bad connection somewhere??? Can anyone help me with this? thanks!
Old Mar 24, 2003 | 08:11 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
it sounds like a bad battery conection, make sure the terminals are clean and tight
check and clean grounds, clean engine to frame ground.
Old Mar 24, 2003 | 09:15 PM
Car: 89 Camaro
Engine: 355
Checked
Yeah the connections are tight, and I have a new motor in it so its as clean as it can be. I have had this problem ever since owning this car though.
Old Mar 25, 2003 | 01:54 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
is there an ign. relay on the car? that could have corrosion on the pins or be going bad
Old Mar 25, 2003 | 03:28 PM
Car: 89 Camaro
Engine: 355
Ign. relay
There sure is, right next to a fan relay for cooling and it too has been replaced already.
Old Mar 26, 2003 | 07:34 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
how old is the battery?
check the fluid in it?
some times they get a dead cell and cant provide enough current to start the car.
also if the car isnt driven that often or only on short trips the alt doesnt have enough time to charge the batt.
Orr89RocZ
Apr 25, 2016 08:28 AM
spaigo
Aug 21, 2015 07:46 PM
justin57
Aug 20, 2015 07:05 PM
Bradsaundry
Aug 12, 2015 12:34 AM
hokis
Aug 9, 2015 03:57 PM
