service engine soon
Old Apr 9, 2003 | 04:54 PM
IROC_Vert's Avatar
Car: Camaro IROC-Z Convertible & Camaro
Transmission: Auto & 6 SPEED
Axle/Gears: 2.73 & 3.42
service engine soon
My service engine soon light comes on every time I turn the key to the on position and will go out as soon as I turn the ignition... so far so good, but when I try to read the trouble codes by putting a wire from the 6 to 12 terminal on the ALDL port it just stays on and does not blink at all to give me the trouble code….
The car is running good except for a little power loss above 3500rpms (but that might be because of a problem with the cat) so I don't think the ECM or prom is messed up. What's the problem?
Alex
Old Apr 9, 2003 | 06:11 PM
MasterEvilAce's Avatar
Nice car, but if the SES light goes off when the car starts, then there are no codes to retrieve...
Although i THINK it should blink 1-2 <pause> 1-2 <pause> 3 times or so, anyways..
hmm
Old Apr 9, 2003 | 06:34 PM
IROC_Vert's Avatar
Thanks..... are you sure that if the SES goes out after the start of the engine that there is no fault code possible to be there ?
Old Apr 9, 2003 | 07:20 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The SES light with the key in 'run' (but engine not running) position is normal.
As far as code retrieval (code 12 is normal as well)....
Old Apr 10, 2003 | 01:27 AM
SlowMaro's Avatar
i think its a to b, ..but some were A to M for some reason...i forgot what year that was on ...im not much help here....but the light is supposed to come on, and when you chekc the trouble codes , its supposed to have one long bling...pause.. the n two short blink....three times in a row....then after that, the trouble codes should blink
Old Apr 10, 2003 | 02:59 PM
True. I heard this too. not Sure when the change was made, though
Old Apr 24, 2003 | 01:23 PM
sub's Avatar
sub
I thought that was normal ... in every car I've ever driven the SES light is always on until it's started. This is true for my '87 Camaro and my stepfather's brand new Ford F-250. Since the engine isn't *on* the sensors think something's up, unless the ECM just isn't running, I'm not sure how that works.
But like I said, I'm pretty sure that's normal.
Old Apr 24, 2003 | 02:34 PM
SlowMaro's Avatar
its completly normal
Old Apr 29, 2003 | 05:43 PM
philoldsmobile's Avatar
Car: 2009 Volvo V50 R Design
Engine: 2.0 turbo diesel
Transmission: 6 speed auto
Axle/Gears: yes, both
its a check position. if the ignition is on, without the engine running, expect to see the SES light, and the choke light (carb)
as long as the SES light goes out when the engine starts yer in the clear. the reason you have no fault codes, is that you have no faults!!!!
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
