can't believe I lost the instructions
Old Apr 9, 2003 | 09:22 PM
j91z28d1's Avatar
I have a t56 swaped into my 91 z28
I had to pulled the trans out and unwired my cyberdyne speedo
converter box and now can't remember how I hooked it up
I looked on the net for cyberdyne and I can't even find a web site for them
I was hoping someone might have there's and could scan one for me
I know Its a lot to ask but I can't think of any other way to get them
Old Apr 13, 2003 | 11:26 PM
MidnightMover's Avatar
have you had any luck getting instructions I have been trying to find them also
Old Apr 14, 2003 | 09:50 PM
j91z28d1's Avatar
none. I E-mailed skulte, thats where I got the crossmember and the part# for the box.
He replyed that didn't have his anymore to try calling Cyberdine.
I haven't tryed yet I think the changed names and stoped making them because when I first order it they said it didn't work on all cars and they didn't know why. so I think they stoped selling them
Old Apr 14, 2003 | 09:52 PM
racerx004's Avatar
Have you tried calling cyberdyne directly too get instructions?
I have the digital dash panel that replaces the gauges in the older camaros, but i don't remember having a speedo converter box.
All i had was a speed sending unit that mounted to the tranny(it ran off a plastic pin because the speedo in mine is cable driven).
Don't bother looking for a web sight because they don't have one.
Here is there listing
Cyberdyne Insturmentation
205 main street, New Eagle, PA 15067
(724)258-8440
Old Apr 15, 2003 | 10:20 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Ive got intellitronix(same as cyberdyne)which is now nordskog.i still have the instructions.my car is an 84z28 though.My speedo is cable driven,no box either,uses the intellitronix speed sensor.Let me know if you want a copy.....
Old Apr 15, 2003 | 10:50 PM
j91z28d1's Avatar
I'm not sure its the same.
the box has like 8 wires coming out it and you only use a few.
If you have a scanner and think it may be the same then yes please.
If not thanks anyways
I'm still looking it has to be someware in my house
Old Apr 15, 2003 | 10:51 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
what is the box for speedo or cluster.
Old Apr 15, 2003 | 11:29 PM
j91z28d1's Avatar
oh yea it might help it i tell you what i need
When you put a t56 in a 90 or newer 3rd gen they have a electric speedo so you can get this box from cyberdyne so you can cal your stock speedo and make it work.
but I pulled my trans unhooked some wires and set it aside thinking I had the wiring dieagram
Old Apr 15, 2003 | 11:35 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
well,the only 8 or so wires i have are on my cluster.Then theres the sender for the speedo,but it only has two wires(700 r4) & mounts on the tranny cable housing.Those are the only two items from intellitronix.Maybe your is totally diff then?
Old Apr 16, 2003 | 06:45 PM
j91z28d1's Avatar
yea. it would go between your cluster and the sending unit on the trans. then mount inside so you could use it to calibrate the Speedo.
because a t56 doesn't have any gears to changes like a 700 or a t5 used just a wheel
Old Apr 16, 2003 | 08:42 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Have you tried calling nordskog.They purchased intellitronix,which was started by one of the original partners that started cyberdyne,Thats probably why both are practically identicle.I might have their ph#.Maybe they can help you.Theyre located in cali now.
Old Apr 16, 2003 | 10:31 PM
j91z28d1's Avatar
yea i think i can find it
I've been to there web site
I'll keep you posted
Old May 24, 2003 | 01:08 PM
j91z28d1's Avatar
if you still need them I found mine
i don't have a scanner but i can try to take a picture and maybe that will help
Old Jul 24, 2003 | 12:22 PM
If you still have it I could still use it
Old Jul 24, 2003 | 01:40 PM
j91z28d1's Avatar
i got them but i need to find a scanner
Attached Thumbnails can't believe I lost the instructions-copy-3-image-05
Old Jul 24, 2003 | 01:55 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Cant even post a pic too big.Let me know if you want an email copy....
Old Jul 27, 2003 | 06:16 AM
Ok, no problem.
Elephantismo
Feb 13, 2019 12:51 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
