gonna need serious help with this one....
Old Apr 18, 2003 | 06:44 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
ok, well here it goes
my 87 Z28 is my project car
last fall i pulled out the ECM and what was remaining of the engine's emission controls part of the wiring harness
tonite i hooked up my starter and connected the battery
turned the key, nothing from the starter
i checked out the battery with a test light checked OK
poked the positive wire going to the starter and then held the other end to ground at various places...........checked out OK
tried to turn on my blinkers....nothing
checked the dome light for voltage nothing
it seems like nothing happened when i turned the key to the RUN position
i should note that i do not have my nuetral safety switch wired on my megashifter yet..........
help me out here
i didnt spend to much time on it tonight cuz its getting dark and cold outside
Old Apr 19, 2003 | 05:41 PM
ok made some progress today
figured out what some wires are and whatnot
what wires should be going to the small terminal on the starter solenoid? the purple wire coming from the ignition switch is one of them
on the starter solenoids large terminal i have the large black positive battery wire
it also looks like 2 red wires from the ignition switch were connected there
btw, i did buy this car as a ex-hack job
basically i need to know what my starting/charging/ignition system should look like
also, the main power feed to the fuse box, where should that be coming from?
Old Apr 19, 2003 | 10:36 PM
ok got my starter wiring figured out
just really need to know where the red wire off my alternator goes to (the one coming out of the 3 wire connector)
Old Apr 19, 2003 | 11:31 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The purple wire is the only wire to the small terminal on the starter. That red wire should go to the starter as well (year depending).
Also. you'll need a jumper between the yellow and purple heavy gauge wires on the neutral saftey swith harness plug to send power to the starter if the switch is not plugged in.
Old Apr 19, 2003 | 11:41 PM
thanx deadbird
its an 87 Z28 with an LG4, and if i remember correctly, i did indeed pull that red wire off the starter
Old Apr 20, 2003 | 10:49 AM
ok still having problems
what terminal does that red wire go to?
it has a smaller ring............
also what wire is the main power feed to the fuse block?
when i turn the key nothing happens................
(and yes i have a jumper between the purple and yellow wires on the nuetral safety connector)
i have no power going to the fuses either.................
Old Apr 20, 2003 | 11:39 AM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Transmission: 700R4's
I'm not sure about that wire.
The wiring diagram for 1986 shows a red wire. It leaves the pos. battery terminal, goes
through a fusible link, and then on to the fuse panel. Have you check the links?
I'll be going over to my shop in a bit. I'll see if I can find my Haynes manual.
-Jeff
Old Apr 20, 2003 | 12:14 PM
thanx so much
Old Apr 20, 2003 | 12:49 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
I found it. Give me a bit, and I'll scan the start/charging diagram for you.
-Jeff
edit: Here ya go. diagram
Old Apr 20, 2003 | 01:40 PM
thanx
i went outside to change the oil in my sister's neon, so while it was draining i figured i would mess around a little bit with it
i pulled down the fusebox and look at it
reconnected the battery and guess what.............we have power captain! i have an idea as to what i did, but i am not 100% sure since all i did was wiggle around a few wires
crap like this always happens to me
i am going to hunt this problem down though, cuz it could be potentialy dangerous to have a short/open in a circuit like this
i turned the key and the door signal chimed, and gauges went into position
my lights also work
i also have power between the purple and yellow wires on the NSS, however it still fails to crank (probably because the battery only has 9 volts left in it)
thanx so much guys!
Old Apr 20, 2003 | 01:49 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
No problem. I take it you figured out the red wire?
-Jeff
Old Apr 20, 2003 | 01:53 PM
ok i think i know what i am doing wrong............
how many terminals are to be used on the starter?
3 or 2?
(its also very hard for me to see the starter because of the longtube headers i have on)
Old Apr 20, 2003 | 02:02 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Two. (based on the diagram, and my recollection from the header install on my 86.)
The purple wire goes on one. The main cable and the red wire go on the big terminal.
fyi, the red wire goes to the "S" terminal of the alternator, and has a fusible link in it.
-Jeff
Old Apr 20, 2003 | 02:14 PM
ok, i think i got it now
Old Apr 20, 2003 | 02:15 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Just went and check my 86 TA... The two terminals that are used are the main one, and the
small one on the right. (Looking at the back of the starter from the front of the car.)
-Jeff
Old Apr 20, 2003 | 03:27 PM
ok cool thanx
Old Apr 20, 2003 | 03:50 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
No problem. Glad to help.
Old Apr 21, 2003 | 05:53 PM
thanx guys almost got her started up today
i had her cranking for a while, but i must have a loose wire, cuz i went back to crank it again and i had no power............i believe its the wire to my fuse box, cuz thats the wire i jiggled the other day and after doing so had power
i'm gonna play with it again wednesday night
Old Apr 22, 2003 | 03:04 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
-Jeff
i have a chiltons but the diagram sucks this one is much better. thanks for posting it up.
Old Apr 22, 2003 | 09:10 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Cool. Get that wire fixed. I don't wanna read about a car-b-que.
No problem.
-Jeff
Old Apr 23, 2003 | 08:52 PM
ok folks, got it up and cranking...........still have to set up my distributor tomorow night
thanx once again
92projectcamaro
Dec 8, 2015 12:25 AM
Zane Story
Oct 8, 2015 12:40 PM
91 SrS
Oct 7, 2015 04:32 PM
gmoutdoorsman
Oct 3, 2015 11:42 PM
Vincent135
Sep 28, 2015 10:50 PM
