Need speedo help with 4L60E swap.
Old Apr 26, 2003 | 03:28 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have been searching for the past hour or so and can't find the answer I am looking for.
I need to know what type of signal is coming out of the VSS buffer box and into the speedo itself.
My cluster is an 86 Trans Am 140mph unit.
I have an external VSS buffer box.
Here are some other specs on the car.
95 LT1 with 4L60E.
I noticed on my friends swap when we were calibrating his Autometer Speedo that it was receiving 4000 pulses/mile from the VSS wire that I assume was tapped off of the computer (it's a custom harness from Speartech).
My other questions are, can I hook up my Speedo to the VSS wire off of the computer or do I need to use the buffer box, and what type of signal goes from the buffer to the speedo.
Thanks.
Old Apr 26, 2003 | 03:49 PM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
On my 90 RS, LT1/4L60E swap the speedometer is hooked directly to the pcm bypassing the buffer box.
Old Apr 26, 2003 | 03:58 PM
Zepher's Avatar
I assume that it works for you with no problems, right?
If so, then I should be good to go.
thanks
Old Apr 26, 2003 | 04:04 PM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
Yes it works great. Of course you will have to have your pcm programmed for your rear gears for it to be correct.
Old Apr 26, 2003 | 04:13 PM
Zepher's Avatar
Thanks.
Programming shouldn't be a problem. I have to go in there and turn VATS off as well as change a few things like raise the speed limiter, turn off any smog crap, etc...
I'll be using TunerCat since I am very familiar with it and the DEF file for an LT1 is only $20.00.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
usafirebird
Sep 29, 2015 11:58 PM
